跳转到主内容
加入维修社区 - 创建账户
Mazda Millenia 是日本汽车制造商马自达(Mazda)在 1993 年至 2002 年间生产的一款行政轿车。
ignition problems need help
My starter stays on after car starts
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Sounds like the Bendix spring is sticking.
Take it to a qualified mechanic for repair.
由完成的 分享
添加一条评论
1个答案
最有帮助的答案
James Clark  could be bad wiring to the starter,  stuck starter solenoid, a bad ignition lock cylinder that keeps the actually ignition switch in the START position as well as a few other things. I’d start with jiggling the ignition lock a couple times in different directions etc. to see if that fixes it (unless you can get to the harness and “hotwire” it that way you bypass the lock totally;-) If that did not change anything, replace the starter/solenoid and see if that fixes it. Here is a schematic that should be identical to your system (depending on exact model/year).
Let us know what you find.
这个答案有帮助吗?
得分 1
1条评论:
James Clark It seems that the starter solenoid contacts are sticking and not releasing the solenoid, as mentioned the return spring could be broken also.
由完成的 分享
添加一条评论
添加你的答案
James Clark 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 31
总计 645
