跳转到主内容
有关用于特定任务(如固定、建造或切割)工具的维修信息。了解如何使用有效的工具来修复坏了的工具。
2231 个问题 查看全部
looking for reasonably priced Canned Air lots
The prices for canned air are just out of hand to me. Does anyone know where I can get reasonably priced air, like six cans at a time. Last time I bought some they checked my ID, and said kids were getting high on it, and then they taxed it - AIR. What's next, bottled water? Remember drinking water out of the end of the hose?
UPDATE
7/29
Received my case (12 - 8 oz) of air yesterday. 8 days from order date http://www.supercannedair.com/ The gas does not stink. Total cost $$3.05 per can. Looks like I have found my supplier!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
8条评论
Nice question. I will look around. I need some myself. I am actually thinking about getting a couple of cases of it the way the laws are going. Technically most of it is not "air". It is R 134A refrigerant. Why kids would want to inhale that is beyond me, yet a well documented problem.
完成的
gee you guys are posh..fancy being able to afford canned air! and water from a hose pipe... we have to pay the government for ours! ;-)
完成的
i know it's what you use but is there not a reusable, more sustainable option than canned air??? can you not get an air compressor that could be used, sort of like the garages have for tyres? what amount of psi are you wanting?
完成的
This popped up while I was doing a search for Canned Air & lots. The price sure seems good. Anyone ever used it: http://www.supercannedair.com/
完成的
The kicker seems to be $14 shipping, but it still looks like $3.00 per 10 oz can delivered. Any thoughts?
完成的
显示更多的3条评论
添加一条评论
5个答案
已选择的解决方案
ebay is my friend....http://cgi.ebay.com/BLOW-OFF-DUSTER-12-P...
and the smaller ones http://cgi.ebay.com/12-Max-Blow-Off-1229...
这个答案有帮助吗?
得分 4
1条评论:
I bought a case of Blow Off about ten years ago. It was OK if you took it outside, but it really stinks.
完成的
添加一条评论
最有帮助的答案
Hello Richard, I use canned air so seldom I forget what I paid for it but use a product called CleanSafe which does the job for me. I'm including a link to their website for your perusal. I hope you find what your looking for. Ralph + http://www.iqproducts.com/dust_ideas
这个答案有帮助吗?
得分 5
1条评论:
Thanks, Ralph, Amazon has it at $5.89 for 10 oz
完成的
添加一条评论
What about a small air compressor you would use for an airbrush mayer? Ive thrown this idea around for awhile, but havent took the plunge yet... You can get one fairly cheap at harbor freight.
这个答案有帮助吗?
得分 4
4条评论:
I did that for a while but the problem is portability. For the big blow outs I need to take it outside. But I also need just a few puffs at times.
完成的
At harbor freight they have this can that can be filled with liquid and you use your air compressor/tire pump to pressurize the can. It isnt the most ideal set up, but could prove to be valuable if you have more than one of them set up.
完成的
Hector - I'm not trying to blow liquids. How is this relevant?
完成的
The thing is, you dont have to use it with liquid. You can just pressurize it and use it as is.
完成的
添加一条评论
Don't buy canned air. One of my best investments into my repair shop is a portable plug in air blower, and BONUS, it is made in The U.S.A.
I do a $9.95 clean out service, for pc's, and it has paid for itself in 4 months 20+ times over. It's great for blowing out any system before dragging it into your shop too.
Warning! Don't stick on the fine tip nozzle and blow straight onto motherboards, the first time I used it I blew off 3-4 capacitors. <really>
http://www.amazon.com/Metro-Vacuum-ED500...
这个答案有帮助吗?
得分 2
8条评论:
A nice alternative to stinky gas cans
完成的
yeah, mayer, and it's a one-time investment. That blower is like the big bad wolf compared to a can of air that's like a smurf sneeze. No condensation either.
Btw, anyone reading this, check that Amazon link above for the Metro Vac, scroll down and watch the video. It will 'blow' you away ~ pun intended.
完成的
My blower paid for itself again today. Worked on 4 laptops, all just clogged up airflow. $280 earned today, not counting past uses, not bad for a $60 investment. It would have taken 4 cans of air-n-the-can to remove half the dust from one of the laptops.
完成的
Btw, compressed air <pfft>, blow $6 on a can and get at most about 4psi and condensation vs $60 for an ac powered, filtered system that blows around 300psi with the small nozzle on.
完成的
I'll have to wait till I finish the case I got ;-)
完成的
显示更多的3条评论
添加一条评论
Best place I've found is Costco, they come in packs of 6 i think and it was the cheapest place last time I bought any. Only problem is you need to be a member to get into Costco, so unless you're a member or you have a friend who is a member, i guess this won't be much help! I'll keep my eye open as I'm running low as well.
这个答案有帮助吗?
得分 1
2条评论:
you also have to have one around you
完成的
ah, that would be helpful i guess!
完成的
添加一条评论
添加你的答案
mayer 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 7
过去 30 天: 10
总计 1,136
