跳转到主内容
加入维修社区 - 创建账户
JBL Charge 2+ 是由 JBL 生产的第二代 JBL Charge 系列产品。
My speaker wont charge
why wont my speaker charge and how do I determine whether the charging port or the battery is gone bad and how can I get replacement parts
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
gcbarber  if the schematic would be available one could simply check the power supply line and thus check to see if the charging port works. But it is not available. So at this time you can change the battery first and see if that resolves it. While you are taking the speaker apart, plug the charging cable in and use a Multimeter to measure on the backside of the port if it shows power from the charger getting through the port. Also measure the voltage on the battery cable to see if you get power. If so it is not your charging port and if no power comes through it is your port. I’d go with a new battery first. JBL Charge 2+
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
gcbarber 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 15
总计 335
