跳转到主内容
一款三星发布于2018年8月的智能手表。
How replace Back Rear GLASS in Samsung Galaxy Watch SM-R800 46mm?
I need replace Back Rear GLASS in Samsung Galaxy Watch SM-R800 46mm.
I am looking for detailed guide for replacement.
Thank you for your help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
2条评论
Any hint where I can get a new Rear glass for the SM-R800? Mine is broken yesterday :(...
Thanks for any hint!
完成的
添加一条评论
2个答案
最有帮助的答案
@aileenmk review step 4 and 5 of this teardown Samsung Galaxy Watch 拆解
这个答案有帮助吗?
得分 1
1条评论:
I ask about ONLY glass, not about all rear case!
完成的
添加一条评论
I did it with mine. It's pretty straight forward. After removing the back plat the heart rat monitor is easy to access and remove. Heat the glass from the outside for easy removal. Although be cautious as the small frame for the heart rate monitor can warp (this is what happened to me). Remove the old tape then place the new tape and glass (kinda like tempered glass screen protector) making sure that all the holes line up correctly.
这个答案有帮助吗?
得分 0
1条评论:
saludos mi reloj tiene un problema es que se apaga y creo que es la bateria pero me dijeron que es porque no tiene el cristal del sensor me gustaria saber si le funcionaba bien el reloj sin el cristal del sensor
Google Translation
Greetings my watch has a problem is that it turns off and I think it is the battery but they told me it is because it does not have the sensor glass I would like to know if the watch worked well without the sensor glass
完成的
添加一条评论
添加你的答案
aileen.orchid 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 17
总计 6,431
