跳转到主内容
2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
Problem after replacing battery
I have replaced the battery in my MacBook Pro model A1398 following your guide.
Now when the MacBook restarts, the fan is running very quickly and the MacBook is running VERY SLOWLY as if the CPU is being throttled to a point where the system is unusable.
I have tried following steps to reset the SMC but this makes no difference.
Please help!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
7条评论
Install this app CoconutBattery take a snapshot of the main window and paste it here for us to see 在已经存在的问题里加入图片
完成的
Hi Dan,
Thanks for the quick reply.
At the moment, the MacBook is running SO SLOWLY it is almost impossible to install any new software. When I click on something it takes about 5 - 10 mins to respond.
Could the problem be with a fault temperature sensor?
完成的
You might have got a faulty battery there. Try disconnecting it and see if your Mac gets back to normal just running off the magsafe. That would give some kind of answer to start with.
完成的
Unfortunately, have the same problem with battery disconnected (running off external power).
The trackpad ribbon cable was replaced during fitting the battery.
I have carriedout some more research and it appears that the riboon cable needs to be "matched" to the trackpad assembly. There is a thermal sensor in the track pad that does not report acurate temperature information if the ribbon cable is not "matched" to the trackpad.
I have now ordered a complete trackpad assembly and will see if this resolves the problem.
完成的
Can we see the CoconutBattery screenshot so we can see it. If you have a second Mac you could create s bootable USB thumb drive and use it to boot your system and as you can setup CoconutBattery on it to get what we need.
Until we see it you maybe replacing things you don't need to. Getting the wrong cable can indeed mess things up but its not matched to the trackpad per-say.
完成的
显示更多的2条评论
添加一条评论
1个答案
已选择的解决方案
Try starting up in Safe Mode by holding down the Shift Key on start up, let’s see if this slow down is related to software. I have seen this several times, especially if you are running an older version of MicroSoft Office.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Darrell Haslam 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 3
总计 186
