跳转到主内容
加入维修社区 - 创建账户
Kenmore Elite HE3 是 Kenmore 生产的一款洗衣机。它与 Whirlpool Duet 完全相同。
Washer says control locked
How do I unlock the controls?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 16
12条评论
Ken, great that mayer's solution worked for you :-) all you have left to do is to accept the answer as a solution. This way we all know in the future what to look for.
由完成的
Thanks Holly! :)
由完成的
It worked for me just now, too! Thanks a ton!! 12/15/2015
由完成的
Yay! Drain/spin and start button worked for me as well! Thank you, you saved me a service call!
由完成的
Thanks "Loads"! Yeah!
由完成的
显示更多的7条评论
添加一条评论
9个答案
已选择的解决方案
Try unplugging it for 5 minutes and then plugging back in.
这个答案有帮助吗?
得分 4
8条评论:
It worked, thank you. Ken
由完成的
Glad I could help
由完成的
It did work for me too, Thanks
由完成的
I cant find the unlock button on my kenmore front loading washer
由完成的
显示更多的3条评论
添加一条评论
最有帮助的答案
abumblebee1, the normal procedure is to hold down the "end of cycle signal" (drain/spin)button for 3 to 5 seconds. The only other thing I could see is that the control interface has failed and has a stuck or shortened keypad. Give it a try and let us know.
这个答案有帮助吗?
得分 13
23条评论:
Holding "Drain/Spin" button down worked for me.
John, July 2013
由完成的
Thank you so much! you guys are great!
由完成的
tony, thank you and welcome to ifixit ;-)
由完成的
Worked for me! Thank you.
由完成的
holding down the "end of cycle signal" button worked for me , thanks.
由完成的
显示更多的18条评论
添加一条评论
The solution for my Kenmore Elite he3 was to press the Drain/Spin button "and" main Start (press & hold) buttons at the same time for 3 seconds.
这个答案有帮助吗?
得分 9
13条评论:
thanks holly martin it worked...
由完成的
Oh good! Glad to hear.
由完成的
worked for me also! Thanks Holly!
由完成的
Thanks, Holly! I bought a door switch from Sears, they said this required it, but I should have read the buttons on the machine! Now I have to beg to get the $80 back, but the machine is fine.
由完成的
Thank you Holly that worked for mine too. I just purchased this set used yesterday and this isn't so user friendly . Hope I don't confine to have problems
由完成的
显示更多的8条评论
添加一条评论
Press drain/spin button and extended spin for 5 mins it will remove the control lock.
这个答案有帮助吗?
得分 4
添加一条评论
This worked for me as a temporary fix. Next load I received a F2 error code. This is a drain pump error. Actually turned out to be a very easy fix also. Removed lower front access panel (3 screws). Removed two screws holding the pump in place (Large round, white plastic canister looking device directly in middle front with screw on cap). After removing the pump pull up and forward. Place a deep pan under the pump, unscrew the cap by hand. There will be a fair amount of water drain. My pump had coins, a pencil and a lot of lint blocking it. Removed all the material, replaced the cap, replaced the pump and front panel. Machine now working fine. Only took about 10 minutes and problem solved.
这个答案有帮助吗?
得分 1
2条评论:
Great tip, cleaning the pump worked for me!
Thanks!
由完成的
Just a note: The white 'box' with the big screw cap is actually the drainage waste collector and the drain pump is actually to the right of that. It's surprising that the manufacturerer did not provide a little door on the front to get to this waste collector which needs to be cleaned regularly.
由完成的
添加一条评论
Hi @lorismith34859
Here's an image from the Kenmore 796.31433710 user manual that shows how to activate/deactivate the control lock feature.
(click on image)
这个答案有帮助吗?
得分 1
1条评论:
THANK YOU!!!!!!!!!!!!!🙏🙏🙏🙏🙏🙏🙏🙏🙏YOU FIXED IT!!!!!!! YOU ARE AWESOME!!!! I was hitting the wrong button! THANK YOU SO MUCH!!!! You’re the BEST! 🤗🤗🤗
由完成的
添加一条评论
Thanks hold Drain and spin button for 3 seconds worked for me thanks to
这个答案有帮助吗?
得分 0
添加一条评论
Have pressed drain/spin button and start button together for 3 second, no help. For 5 seconds, no help. Have unplugged and waited five minutes, NO HELP.
这个答案有帮助吗?
得分 0
3条评论:
@catieb same washer? You have a model number? Control lock shows or are there any other issues? What is going on with it?
由完成的
I have the same issue with model # 79631553610, control lock is on and I cant turn it off, rinse/spin button not working etc...
由完成的
Press and hold the control lock button for about 3 seconds and it will unlock I just did it worked like a charm
由完成的
添加一条评论
My red kenmore elite washer has the start pause button and the power button. It will not unlock at all and my clothes are stuck in it. I tried the unplugging it for 5 minutes and if will not work and sadly my washer does NOT have a cancel button. I need help please I’m desperate
这个答案有帮助吗?
得分 0
4条评论:
Hi @meldes ,
What is the model number of the washer?
由完成的
@jayeff I am not sure. Where would I find it. This washer was here when we moved in a little over a year ago so I’m not familiar with it
由完成的
@meldes
Maybe check at the back either top left or right side. If not unfortunately it will be inside the door jamb.
Different model have different ways to open the door so knowing the model number will help.
The user manual wasn't left there by any chance, as the model number would be in it?
由完成的
@jayeff
I didn’t see anything last time I was down there last night but I will check later in the morning.
由完成的
添加一条评论
添加你的答案
abumblebee1 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 67
总计 74,352
