跳转到主内容
加入维修社区 - 创建账户
Panasonic Lumix DMC-TZ5 发布于 2008 年 3 月。它是 TZ 系列的第三款相机,拥有 3.0 英寸显示屏、28-280 镜头(10 倍光学变焦)和 910 万像素。TZ5 还具备 720p 高清视频录制功能。
Camera will not turn on.
The battery is fully charged. (I tested two different batteries.) When I slide the on button, nothing happens. I've cleaned the contacts with alcohohol, with no change.
What's the next step?
Update
Thanks for your input. After cleaning the contacts and switching batteries again I got it to work. I checked with a multimeter and the one battery was a little low. So maybe, that threw me off.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
brilliant. glad you didn't have to tear the whole camera apart! we've all had bad batteries make our gadgets fail, but it's better than replacing expensive parts.
由完成的
Thank you very much!! Alcohol worked so beauifully!! For people who are not familiar, the contacts are the metal points of the battery that make contact with the camera unit. A gentle application of alcohol with a Q tip did the magic!!
由完成的
添加一条评论
2个答案
已选择的解决方案
try taking a look at this guide it may be the i/o board which apparently you can replace.. you could try testing the battery contacts with a multimeter to check that you have a circuit
这个答案有帮助吗?
得分 4
1条评论:
+ just because the battery does have a charge does not mean it gets to the camera. Time for the multimeter...
由完成的
添加一条评论
i am also grateful! i was online to buy a new camera because mine wouldn't turn on. i had charged and tried 3 different batteries, and nothing. the solution was so simple! thank you!!!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Toby Olssen 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 68
总计 15,239
