跳转到主内容
The Canon PowerShot A720 IS is a point-and-shoot camera with 8.0 megapixel resolution and a 6x optical zoom.
Will not hold time and date
When I switch the camera on, the set time and date message comes on the screen. This has to be set before the message clears from the screen. The next time the camera on you have to go through the same procedure again.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
I have a similar camera (A570 IS) and mine has a second type of battery right beside the two main AA ones. It’s under a cover marked “CR1220” which refers to the type of that second battery. Pull that cover up, replace the CR1220 (or whatever battery type your camera has) and that should fix the problem.
这个答案有帮助吗?
得分 4
2条评论:
i tried that and it didn;t work
完成的
@williams679 what make and model camera? what were the issues and what did you try?
完成的
添加一条评论
最有帮助的答案
If the battery level drops to low, a board will lose its memory. Replace the battery.
这个答案有帮助吗?
得分 4
1条评论:
I have already replaced the batteries but problem still exists.
完成的
添加一条评论
添加你的答案
rogerdeans 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 20
总计 991
