跳转到主内容
Repair and support for ceiling-mounted bladed fans.
My ceiling fan doesn’t blow down like it’s supposed to
Any ideas as to why my ceiling fan isn’t blowing air like it’s supposed to? We’ve cleaned it, even tried switching the blades around and nothing…
can anyone help…
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
2条评论
This is an easy answer
完成的
Are there directional buttons on the fan’s remote control?
完成的
添加一条评论
3个答案
最有帮助的答案
@shanersgirl1 there should be a switch on your fan that let’s you reverse it’s turning direction. See if that makes a difference. For as long as the fan moves it should be pushing air, no matter what.
这个答案有帮助吗?
得分 1
1条评论:
We tried that, I just looked and it’s down… idk thanks though
完成的
添加一条评论
Try changing the capacitor in your fan. Check the old capacitor & replace with ane with similar rating.
For example, If 2.25uF is the calculated safe capacitance that is in the fan; 2.5uF can be used in place of 2.25uF (as it is one of the closest value) can be used, without increase in temperature of the fan motor beyond its failure. The speed of fan will slightly increase with slight increase in temperature of winding. But you may find very less reduction in speed control in lower speeds.
这个答案有帮助吗?
得分 0
添加一条评论
Just below the main stalk of the fan, there should be a switch for changing the direction of spin.
Because the blades are slanted, one direction causes air to move up (for summer), the other direction causes air to move down (for winter).
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Keri Castro Holady 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 40
总计 9,249
