跳转到主内容
iFixit 使用 cookie 来增强网站功能、分析流量和个性化广告。使用本网站即表示您同意我们的 cookie 使用和隐私政策
The Nintendo DSi is the third iteration in the Nintendo DS line, and made its debut in Japan in late 2008.
dsi flashs on and then turns off
i got a dsi that will turn on and then it turns off immediately after i hit the power button. i think it may have a fuse that may be bad im not sure but i wanted to check on here before i took action on trying to fix it
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 7
5条评论
I dropped my ds in the toilet and it does the same exact thing.
完成的
Ya know that if you drop it in water it will not work right because of a short!
完成的
My dsixl is not working only the orange things turns on and. The blue and yellow don't what shall I do
完成的
Mine does the same! But i havent used it since i was six. Which is four years. I think its the battery im replacing it but what if it doesnt work?
完成的
I dont think its water damage though. I sprayed perfume on it but it still worked. Maybe it soaked in but i dont know. Only one screen (the bottom one) turns on then in a second off. It has a brown tinge to it as well when the screen is on it look brownish. It could be the perfume?maybe being untouched for four yeras soaked it in?
完成的
添加一条评论
2个答案
已选择的解决方案
Your problem is not fuse related. 1 of the fuses is for the charging circuit if it is bad the unit will turn on fine with a properly charged battery. The other fuse is to the power circuit if it is bad no lights will light and you can't charge the battery. Your DSI is flashing on and off because something is shorting. If only 1 screen is flashing the problem is more than likely with the other screen. If both screens are flashing then it could be because of water damage, improperly seated cables - more than likely 1 of the ribbon cable to the screens or a bad upper screen ribbon cable that goes through the hinge. This guide here will help you tear it down to inspect for water damage and how to get to the cables. If you find residue or other signs of liquid damage please see the water damage tag for solutions to that. Your ribbon cables need to be sitting square and true to the socket they go in. Please be sure the flap that holds the ribbon cable in is flat and even, sometimes they like to bow up or out in the center. If you are certain there is no water damage and that all the cables are seated properly more than likely the upper LCD will need replaced because there is damage to the attached ribbon cable - even if signs of damage aren't visible. That part is available here. The same guide will apply.
这个答案有帮助吗?
得分 12
2条评论:
In my case it was exactly that! Since one of the two screens was only flashing, the other was shorting. By adding some electrical tape between the circuit and the ribbon cable of the shorting screen, it was gone!! Thank you!
完成的
I don’t know if you’re still active but is it just basic black electric tape and was it straight on the ribbon cable to the board
完成的
添加一条评论
i can help two wires at the bottom right on the board of your dsi has gone bad here is a pic of them
这个答案有帮助吗?
得分 2
2条评论:
Hey azzy cant find the pic u added i got this problem cud u send
完成的
添加一条评论
添加你的答案
ben 将永远感激不已
浏览统计数据:
过去 24 小时: 15
过去 7 天: 89
过去 30 天: 382
总计 77,320
