跳转到主内容
Repair guides and support for your Samsung TV.
Screen with vertical lines
Hi,
Recently, vertical lines start to appear on the screen. is it damaged LCD or what else?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
Hi kok wee ng,
It sounds like either your graphics processor in your TV is going bad, or the LCD is starting to break inside and not display images correctly. I would try messing around with some video settings on your TV to see if the various lines get stronger or lighter with adjusting the color, contrast, etc. If you adjust your brightness to full and the lines are as bright as the rest of the TV, then the graphics board is going out. If you adjust it to minimum and the lines are still there, the LCD is most likely going out.
Best Regards,
Drew.
这个答案有帮助吗?
得分 0
1条评论:
thanks for the reply. no diff to the lines brightness so i guess the LCD is dying
完成的
添加一条评论
'''++kok wee ng++'''  if this is over your entire screen I would check the T-con board first. If you give us the model number of your TV we can try to find more information about this. It is of course possible that these are TAB errors (unlikely) where the ribbon cables from your driver board for your LCD (unrepairable) release from their contact.
这个答案有帮助吗?
得分 0
1条评论:
thanks for the reply. the model is UA55ES7000
完成的
添加一条评论
I have the exact same problem with my Samsung hi-def big screen and quite by accident found a way to “fix” the problem when I was plugging in a cable cord. After fiddling and wiggling the cable cord I eventually found the “sweet spot” and my picture returned to a beautiful screen display again! The only problem is if I accidentally turn off the tv I have to manipulate the cable cord again. It can take a bit, but eventually I find the sweet spot again. The odd thing is - the other end of the cable cord isn't attached to anything!
Hope this works for you, too. Worth a try.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
kok wee ng 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,402
