跳转到主内容
The Tiida(Versa) hatchback and the Tiida Latio sedan debuted in 2004 in Japan, and in select European countries in 2007.
Reverse camera RCA cable
Hi There,
I have panasonic cn-hds625d and need to get a RCA cable for the rear view camera. Please advise what is that slot type called and where it is available. This car is currently in Newzealad and it is an Japan Import car
Sorry. Missed to update the image... adding it now.. Please also where i can get these cables in Newzealand.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
'''++ttsenkumar kumar++''' not quite sure which slot you are talking about. I suppose you are referring to the rear camera slot. You can always post some images of what you are looking for with your question. Use this guide 在已经存在的问题里加入图片 for that. That is most likely proprietary and without a proper schematic it will be extremely difficult to source it. I do believe that there is a rear camera kit for your navigation model Check for something like YESFX999101
这个答案有帮助吗?
得分 1
1条评论:
Thanks Mate... Just added the picture
完成的
添加一条评论
添加你的答案
ttsenkumar kumar 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 464
