跳转到主内容
A digital camera designed and manufactured by Sony in 2012. A 18.2 megapixel camera with Wi-Fi, GPS, and a memory card slot.
Why is my camera making a strange noise?
Hi, when I power on my camera and the lens comes out it imediately starts to make a strange humming vibrating noise. The camera still works fine, but the noise is killing me.
Looks like the auto focus or the stabilizer is constantly adjusting. Is there a solution for this or should I start looking for a new one?
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
2条评论
Hello, My sony hanycam have the same problem, it keeps buzzing, please help me
完成的
Check out earlier answers.
Hans N.
完成的
添加一条评论
4个答案
最有帮助的答案
I had the same problem, this humming vibrating noise when powered on.
I took the camera apart and opened the lens system and saw that there was lots of dust particles where the autofocus is. The autofocus is no motor but a sliding head on a magnet carrying a focus lens.
I cleaned this place, the focus lens and the image sensor using a small painting brush and an air blower, put it all together and the noise was gone! What more, the pictures became a lot clearer and well focused.
这个答案有帮助吗?
得分 1
3条评论:
Hi, thanks for your answer. I have never taken a camera apart, let alone a camera lens. I know theres a guide for it here, hope its not to difficult and that no scrwes are left after assembly.
完成的
Here are some links for you:
Sony Cyber-shot DSC-HX20V Lens Assembly Replacement
https://www.youtube.com/watch?v=fE0vQmQF...
The last one is for another camera but it shows how to do it.
完成的
For HX30V (and HX20V) be aware disassembling the optics requires to unsolder two plastic ribbon cable one from another. In fact they have soldered two plastic ribbons together during manufacturing, and it's hard to unsolder without melting the plastic of either ribbon, even with high soldering skill and quality solder iron. I can't imagine re-soldering those two plastic ribbon cables together.
Most likely you'll do like me and melt the two cables.
If you look at this video https://www.youtube.com/watch?v=gK3BgqS-... at 5:15 he's skipping the part where he dealt with the soldered ribbon cables using a video transition. During the transition he has unsoldered those wires and at 8:45 there's another transition where he has supposedly re-soldered them. But maybe he couldn't handle them and damaged the optics but hide that from the video (at the end we don't see whether the camera works or not, smart chap)
完成的
添加一条评论
@aljo any chance to narrow the location of this noise down? I would think that the only thing that could make that noise is the motor on the lens assembly. If nothing else I'd try a new lens assembly. Check ebay etc. for replacements
Use these guides Sony Cyber-shot DSC-HX20V to work on your camera.
这个答案有帮助吗?
得分 0
添加一条评论
I guess it is the lens motor, no other major moving parts... With the guide I can just put the camera apart, no fix for the motor.
Anyone had the same issue and found a solution?
Update (03/03/2018)
oh my oh my…
I accidentally found this thread again and would first like to apologize for the delaaaaaaayed response and express my gratitude for the help of course because the lens disasembly worked and the noise was gone.
I forgot about this because I did not start the repairs immediately :)
Camera still works.
So a big thanks for help because I still have a great secondary camera at hand ;)
这个答案有帮助吗?
得分 0
1条评论:
what did u do to stop the noise??
完成的
添加一条评论
Oh yes.... this problem is very common on the Sony HX20.
The most common cause is that the camera is letting dust into the optics so that the focus system gets disturbed causing vibrations and blurry focus.
The remedy is to open the camera and clean the lens system. It's quite tricky, I've done it several times but unfortunately it doesn't last very long.
If you dare to try it see the instruction Sony Cyber-shot DSC-HX20V Lens Assembly Replacement
I'm very disappointed, it's a great camera when it works.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Aljo 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 25
过去 30 天: 134
总计 12,323
