跳转到主内容
加入维修社区 - 创建账户
戴尔在 2000 年代末推出的高端超便携笔记本电脑系列,旨在与 MacBook Air 竞争。
damaged internal dc plug
I have a Dell Adamo 13, my internal power connector is broken (the one that is on the motherboard) do you know where i can buy only this part or how to repair it? I don't want to change the motherboard becouse it's only a small piece that is broken.
If this part is unavailable do you have schematics of this part?
Do you have alternative solutions?
Thank you very much
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
I believe that it is soldered to the motherboard. So you do have to take it apart and expose it and see exactly what you need Dell Adamo 拆解 shows you how to get it all apart. I would try to either get it from Dell or one you have the part check on Digikey or Mouser.com
这个答案有帮助吗?
得分 1
1条评论:
in the step 21 of the Dell Adamo Teardown is the one in the upper left with the code 932ca
由完成的 分享
添加一条评论
Replacing the DC jack involves re-soldering on mother board and probably it wont be possible with regular soldering iron. I would suggest to take it to some hardware shop and get it fixed because a wrong attempt can may harm your laptop more otherwise you can try by yourself.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Emanuele 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 17
总计 2,072
