跳转到主内容
The Canon PowerShot S90 is a high-end 10.0-megapixel compact digital camera originally announced in 2009.
6 个问题 查看全部
Full battery but won’t turn on
My s95 camera worked well last time I used it but now won’t turn on. I have already ordered a new battery and installed it but still no go. Is there an easy check I am missing?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
I’m having the same issue with my s95. Battery door compartment is all fine but still won’t turn on. Has anyone found a solution please help a girl out :(
完成的
@christina73227 does your S95 give you any sign of life? Checked the battery, just to make sure?
完成的
添加一条评论
1个答案
已选择的解决方案
Ned Hascall start by checking the battery contacts as well as the battery door. If it does not make proper contact your camera will not get any power. Let us know what you get once you've replaced the battery.
这个答案有帮助吗?
得分 1
3条评论:
I am a having a similar issue and have replaced the batteries. Is their another step I can take?
完成的
@Chris Cool Did you check the battery compartment door? If it does not make proper contact it will not work
完成的
Yes I checked the door and it made contact but I was never able to get the camera working
完成的
添加一条评论
添加你的答案
Ned Hascall 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 12
总计 1,003
