跳转到主内容
加入维修社区 - 创建账户
Sony Xperia M2 是 Sony Mobile 生产的一款中端 4G Android 智能手机。2014 年 5 月上市。
Not Charging : Dead
Hi Team,
Sony Xperia M2 - Dead Unit.
Device status & measurements :
The fault is Phone is not charging, USB Power ( 5V, 10-20 mA) Battery Charging voltage 1.1 - 4.1V, current fluctuating.
Note : This is liquid damaged device
Observations & tests
  • TH voltage is 1.2V it seems OK
  • There is no BAT EN signal 0.6V
* Phone can be power on when given the BAT+ - to with external power supply
  • When plug the battery connector 0V at battery terminals. that's mean Battery Disable itself
  • When unplug the battery and can be get measurement 3.7V
  • Checked with new battery, same result observed. - Battery is OK
If any idea please comment. Thank you for your time. in simple i need to enable BAT EN signal or need a way to bypass. or Please help to find schematic diagram for D2303
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Buddhika Mahesh this is going to be tough. There are no more schematics available since Sony does not repair any electrical components anymore.
由完成的
添加一条评论
1个答案
最有帮助的答案
Buddhika Mahesh the only thing you could try is to hack it together like this
from here
这个答案有帮助吗?
得分 2
2条评论:
Already checked the path. 2-3 Ohms. 4.9V there. i need to generate anyhow BAT_EN signal. otherwise have to replace PM IC.
oldturkey - As always, Thank you for helping us! :-)
由完成的
Buddika mahesh im from sri lanka is there a way to contact u
由完成的
添加一条评论
添加你的答案
Buddhika Mahesh 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 31
总计 3,233
