Vacuum not sucking anything up?
The vacuum is clearly powered on but whenever I go over a piece of debris it won't pick it up. What do I do?
Weak suction is sometime due to a faulty brush head. Clogged debris prevents it from revolving properly. You may have to reach into the brush head to remove any debris. If you have checked the brush head and everything seems clear the issue may be the motor. If this is the case consider a motor replacement. For instructions on a motor replacement, see the trouble shooting page Shark Navigator Lightweight Upright Troubleshooting
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 934
2条评论
student question
由 mayer 完成的
Debris only collects in the little space with the big white filter, how do I fix this
由 karen.johnson649 完成的
