跳转到主内容
Released in October 2010, the Shark Navigator is a lightweight upright vacuum by SharkNinja, and can be identified as model no. NV22S.
7 个问题 查看全部
Vacuum not sucking anything up?
The vacuum is clearly powered on but whenever I go over a piece of debris it won't pick it up. What do I do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
2条评论
student question
完成的
Debris only collects in the little space with the big white filter, how do I fix this
完成的
添加一条评论
1个答案
最有帮助的答案
Weak suction is sometime due to a faulty brush head. Clogged debris prevents it from revolving properly. You may have to reach into the brush head to remove any debris. If you have checked the brush head and everything seems clear the issue may be the motor. If this is the case consider a motor replacement. For instructions on a motor replacement, see the trouble shooting page Shark Navigator Lightweight Upright Troubleshooting
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Kahye Yu 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 925
