跳转到主内容
加入维修社区 - 创建账户
发布于 2011 年 10 月 24 日 / 2.2 GHz、2.4 GHz 或 2.5 GHz 四核 Intel Core i7 处理器
2011 MacBook Graphics Card - Out of box solution
My beloved late 2011 15inch MacBook Pro is having graphics card problems. I believe the problem is specifically due to the chip overheating which then causes a number of symptoms - the end result being my display is all messed up.
And I believe the only solution is to replace the logic board - at which point I might as well get a new MacBook.
I had an out of the box solution to run by everyone - I was looking for your thoughts.
If the problem is overheating, is there a product out there that can greatly help keep the bottom of the laptop cool - some sort of high grade stand that cools the computer.
And if there is, would cooling down the computer actually solve the problem.
Looking forward to your thoughts!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 6
添加一条评论
6个答案
已选择的解决方案
The issue here is that even a replacement will eventually fail due to the design of the IC. Here is a very "quick and dirty" explanation of what causes most of these failures.Sometimes it is a failure of the solder balls which connect the IC package to the motherboard. It does happen and you can see why on here. More commonly however is that the failure is due to the chip design itself.
As you can see the "bumps' are what actually connects the die to the substrate to make the chip complete. If these bumps fail, the die does no longer make contact with the substrate and thus no contact with the circuit board. The chip has failed.
Here you can see the space where the bump has failed and no longer makes contact. We are talking microns of space here. So a bit of pressure on the top of the die potentially close the gap. Same with a reflow, it may allow some of material from the bump to reshape and starting to make contact again. The heating of cooling of the chip during use is what will eventually cause it to fail again.
So if anything, the design of a more effective heatsink may provide a more viable solution.
这个答案有帮助吗?
得分 4
添加一条评论
I know this answer is a bit late.
However, keeping the laptop cool cannot help after the GPU has failed.
if you have done the oven trick or replaced said GPU, then most certainly yes keeping cool will stop it happening again.
I use a free app called Macs Fan Control to keep my 2011 Macs cool
这个答案有帮助吗?
得分 2
2条评论:
Good point Gordon. Macs Fan Control is great tool and it works as advertised, though you only truly unlock all the benefits by purchasing it. Which is fine and recommended (support the dev). I know my reply to your 'late answer' is years down the road, but no matter, the internet is forever, right? Cheers~
完成的
Hey Rory, thanks for the comment.
The internet may be forever, but my days of messing about with 2011 Macs are not.
And a good point, we should support the developers of the apps we use, absolutely!
Cheers
完成的
添加一条评论
Sadly you can’t uncrack an egg and in this case you can’t undo the damage caused by the chip overheating over the years you’ve had the system.
But! It may not be doom & gloom here. There are two distinct issues the tantalum caps failing and the other which is the worse the GPU is shot. You’ll need to find someone with the skills to properly diagnose which way your system failed and hopefully get it fixed.
Last glimmer of hope here is you can also force the system to use the Iris graphics services within the Intel CPU. While this will help you limp along for a short time it’s not as powerful a GPU as the Radion GPU.
这个答案有帮助吗?
得分 1
2条评论:
How do you do that? "force the system to use the Iris graphics services"
完成的
@mayer - Here's the tool I use: gfzCardStatus
完成的
添加一条评论
A sollution (other than replacing the mainboard and if the chip isn’t toast yet) would be to properly clean the MacBook and replace the termal paste.
I have got a candidate for that right here, I will investigate and report back.
这个答案有帮助吗?
得分 1
1条评论:
Good point! I just assumed Chris had done this already.
I would stick with Arctic Silver products. The chemistry of the higher thermal products have issues (corrosive and/or conductive) which make them a bad choice in a laptop. Besides, a degree difference is not enough of a gain for the price.
完成的
添加一条评论
Hi there - just had this problem with my early 2011 mbp - it's a very common problem, and a good engineer can buy a new gpu chip and replace without replacing the whole logic board. Just had mine done, and all is well!
Hope that helps
Steve
这个答案有帮助吗?
得分 1
6条评论:
Sorry SDM getting the replacement GPU chip is quite difficult! Unless you but 1000.s of units AMD won't offer you GPU. In addition this is an older version which is not being produced any more.
完成的
Hi Dan - the guy that fixed mine ordered a new part without much difficulty - not sure where from, but he seemed honest and very knowledgeable, he even gave me the the old chip! -He explained all the issues in this thread which is why he recommends not just 'reflowing' but also replacement.
Anyway, considering Apple now class my machine as 'vintage' I'm just please she is up and running again, and hopefully will be around for a few more years :-)
Steve
完成的
Hello Steve, is it possible for you to give some information about the person who helped you get new GPU or may be more information on how/where he got GPU from.
Thanks
Kevin
完成的
Hey SDM, I am in NYC. I am having the same issue on my Early 2011 MacBook Pro. Can you please share contact info for your guy?
Would love to reach out to him.
Thnx so much.
GRG
完成的
SDM: Please please, share with US information about your new chip and the contact of your magic guy. Thank you
完成的
显示更多的1条评论
添加一条评论
Hi guys - I posted a while back saying I had found a guy who sorted out this problem for me - his name is Lee and works in South Woodford, London, right next to the tube station in a small computer repair shop .
He replaced the chip, and the thermal paste. In all honesty the solution lasted about months, and then the same thing happened. I took it back, and he was quite surprised, and so agreed that I only pay for the chip and not the labour this time round. So he charged me £60 as opposed to the £180 he charged last time. Im pretty sure he changed the chip as he gave me the old one!
If it happens again then I guess it will be time to get a new mac! I will try and get his website details if anyone needs it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Chris Coutinho 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 30
总计 19,880
