跳转到主内容
The GoPro Hero3+ Silver Edition (model no. CHDHN-302) was released in October 2013. This digital camcorder is capable of recording 1080p HD resolution video and taking 8MP pictures.
17 个问题 查看全部
Date Time resetting, can I change just the motherboard battery?
My GoPro no longer seems to be holding date/time.
I'm assuming this is due to the motherboard battery?
If so, is that replaceable? If so, what type of battery and are there online instructions?
I've seen the Hero 3 tear down page, so I know it has a soldered on motherboard battery but even that teardown does not remove/call out the onboard battery type and removal/replacement.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Peter Yamamoto you are absolutely right and there is not a lot of information about this battery anywhere. I just checked mine and it is a 3V MS614FE battery manufactured by Seiko. Here is the datasheet DATASHEET SEARCH SITE | WWW.ALLDATASHEET.COM and most likely Mouser.com or Digikey.com will have those.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Peter Yamamoto 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 221
