跳转到主内容
加入维修社区 - 创建账户
Kenmore 微波炉的维修与拆解指南。
Door difficult to pull open
Microwave door difficult to pull open. Is it a hinge problem or a latch problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
Does it swing freely after it is open?
由完成的 分享
I have a Kenmore Elite Microwave and it is hard to open due to the Sagging. The top round portion of the hinge pivoting on the round piece like a rivot is worn flat to the middle of the round piece on one side and has actually started to bend due to the weight of the door. I do not see a way to remove that piece from the upper portion of the door
由完成的 分享
I'm not sure but the whole door drops down about an eighth of an inch so I'm torn between hinges and latch do hinges drop so latch holds?door is hard to pull open
由完成的 分享
添加一条评论
2个答案
最有帮助的答案
@sirjeff unless the door is loose and sagging after it is open, this is most likely a door latch issue. If you let us know what model your MW is we can check for more information.
这个答案有帮助吗?
得分 2
添加一条评论
Had the same hard opening issue
Solved by removing the door from the hinges and gently bending the top and bottom hinge upward a little bit so that the 1/8 inch sag was eliminated on the right hand side of the door - opposite the hinges
The door never closed and opened easier!! 😉❤️
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jeff Ellingsworth 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 2,329
