Disassempling of the Braun EP100...?
How do I disassemple it? It is impossible without destroying the halfshelves that covers it........?
@nlzhlm the EP100 actually is a Braun 5601. Yes it can be disassembled without breaking it. Here is the SM Braun EP100 service manual that shows you how to work on it.
这个答案有帮助吗?
I got the same problem, I need to open it, but arrived to the point where the cover is strongly held. I dont want to force to dont destroy it. did you finally manage to open yours??
Thx
Edit:
Finally I managed to open and repair it.
it felt from my hand, and refused to work anymore.
So decided to open and check the issue. I had to force a bit , nothing to complicated, but the clips were very tied, thats why anyone is scared to insist... Finally it was the negative pin of the battery that was cutted from the board, so just resolder it to the board, and it was good to go :)
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 14
总计 2,035
2条评论
Did you check for a replacement cost from Braun, I just replaced my unit that was over 300 bucks for about 50. Series 7
由 Duane Donaldson 完成的
由 DrZipZwan 完成的
