跳转到主内容
加入维修社区 - 创建账户
家用咖啡机与意式咖啡机的维修指南。
forever blinking in 3 fast 1 pause sequence
Hello!
my Krups Nespresso Inissia XN 100 machine after heating up keeps blinking with the following sequence: 3 fast 1 pause. The assistance said that there is an error in the electronics. Any suggestions rather than getting rid it of my poor Nespresso?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
4条评论
Just spoke with Nespresso customer service: "The Essenza Mini will NOT work with an inverter." Oh well, back to the store... :(
完成的
1. Switch off at wall.
2. Turn on at wall.
3. Hold in the lungo(large cup) in for 5 seconds.
4. Wait for device to heat up.
5. If the lights do not flash then congratulations!
6. Enjoy coffee.
完成的
Genius! It worked.. the relief!
完成的
Francis, it didn't work on my DeLonghi inissia Nespresso, any idea how could I force its PCB to a hard reset?
完成的
添加一条评论
6个答案
已选择的解决方案
@leoborni see if it is stuck in descale mode. Press both green lights for 3 secs and it should flashing at a slower rate. When they stop flashing it should be good to go.
这个答案有帮助吗?
得分 2
7条评论:
Hello!
I checked and it is not in rescaling mode unfortunately.. the blinking sequence is different. I tried many time to press both bottons in different combinations of time and nothing happens :(
完成的
Okay lets see is we can find out more about your Krups.
完成的
What extra info can I give you? I'm desperate for an espresso in the morning T.T
完成的
trying to find a schematic to see what we can check
完成的
do I have to find a schematic? or are you..? sorry.. my English is what it is xD
完成的
显示更多的2条评论
添加一条评论
最有帮助的答案
I’m my case it was the water container had leaked water into the hole underneath, I had descaled using vinegar then done all the cleaning and flushing only for it to start flashing continuously. I removed the water container dried it out and now all fine again, coffee back. It was in the hole not in the round gully that the container sits in. It worked for me hope it works for you.
这个答案有帮助吗?
得分 5
1条评论:
What's happening if you press one button both flashing, and if you press both still doing the same
完成的
添加一条评论
Just wanna ask, have any of you found the solution?
这个答案有帮助吗?
得分 0
添加一条评论
In my case, (after speaking with support) I was told the coffee maker doe not work with power from an inverter, like in a motor home.
Oh well. Returned it.
这个答案有帮助吗?
得分 0
添加一条评论
I just had the same problem, both lights would keep flashing 3 times. Tried pressing them both, pressing one,….
Nothing would work. Switched it off at the wall, waited 5 seconds and switched it back on…
Works perfectly now
这个答案有帮助吗?
得分 0
1条评论:
this worked temporarily, after a few days it failed again until permanently
完成的
添加一条评论
In my case, after reading here, I removed the water container dried the hole put container back and turned it on and it worked fine.
这个答案有帮助吗?
得分 0
3条评论:
Also mine is a Krups Essenza Mini. And not Inissia.
完成的
Unplug your Essenza mini, then plug back in and press/hold lungo (Big cup) button for 5-7 seconds, the espresso (small cup) button will flash very fast 3 times, you have reset your machine and you are good to go. I just did it right now on a customer's machine after trying other solutions.
完成的
@furqanshafi Unplug your Essenza mini, then plug back in and press/hold lungo (Big cup) button for 5-7 seconds, the espresso (small cup) button will flash very fast 3 times, you have reset your machine and you are good to go. I just did it right now on a customer's machine after trying other solutions.
完成的
添加一条评论
添加你的答案
Leo 将永远感激不已
浏览统计数据:
过去 24 小时: 9
过去 7 天: 54
过去 30 天: 300
总计 95,553
