跳转到主内容
The second generation of the Samsung Gear, a round smartwatch running Samsung's Tizen smartwatch OS. The Gear S2 was released in October 2015.
Not keeping the charge
Why is my gears s2 not holding the charge
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
My gear 2 isn't holding a charge all day, what can I do?
完成的
添加一条评论
1个答案
最有帮助的答案
erwinallamby, You can check the 1st 2 links to see if the info. helps gain back battery issue and if no help then faulty battery may be you issue.
If the smartwatch only powers on when connected to the charger regardless of charge time, then the battery is faulty. Replace the battery using last link guide.
https://us.community.samsung.com/t5/Wear...
https://www.youtube.com/watch?v=jR1w9DD_...
https://www.engadget.com/2014/04/09/sams...
这个答案有帮助吗?
得分 2
1条评论:
I upvoted your answer ... however, if you have a link for a GOOD replacement battery for the Gear S2 Classic, I would appreciate that.
完成的
添加一条评论
添加你的答案
erwinallamby 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 4,341
