Not keeping the charge
Why is my gears s2 not holding the charge
erwinallamby, You can check the 1st 2 links to see if the info. helps gain back battery issue and if no help then faulty battery may be you issue.
If the smartwatch only powers on when connected to the charger regardless of charge time, then the battery is faulty. Replace the battery using last link guide.
https://us.community.samsung.com/t5/Wear...
这个答案有帮助吗?
I upvoted your answer ... however, if you have a link for a GOOD replacement battery for the Gear S2 Classic, I would appreciate that.
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 17
总计 4,566
1条评论
My gear 2 isn't holding a charge all day, what can I do?
由 dpkelly54 完成的
