跳转到主内容
加入维修社区 - 创建账户
How to set timing marks
How do I set the timing markings on my 2006 Hyundai Tucson 2.7L V6 2WD.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
I can't seem to be able to get the what to look for when aligning timing marks. I've done it all set all marks. It just won't start, #1 piston at the top, timing marks inside heads match up all marks end up at set point after I hand rotate 4 revolutions. Don't know what else to do.
由完成的
添加一条评论
3个答案
已选择的解决方案
This is a tear down video that's pretty detailed its for a Santa fe but the motor placement and assembly are similar the Tucson
https://www.youtube.com/watch?v=rZ2rtr5-...
This guide may also prove helpful
http://www.hyundai-forums.com/sm-2001-20...
and finally what to look for when aligning the marks
http://thumbs.ebaystatic.com/images/g/r~...
Hope this helps
这个答案有帮助吗?
得分 4
添加一条评论
@lndramirez, Lupe Ramitez , Both links are pretty good at showing the timing line up marks for Hyundai Delta 2.7l V6 engine found in your Tucson. The 2nd link goes through the procedure pretty much step by step with pic's. Good luck.
https://www.youtube.com/watch?v=Ap1XlvKq...
http://www.newtiburon.com/forums/diy-eng...
这个答案有帮助吗?
得分 4
添加一条评论
@lndramirez it would take a while to formulate an answer for you on here. I suggest that, for a great write up on this, check on here.
这个答案有帮助吗?
得分 3
3条评论:
@oldturkey03 @lpfaff1 Well guys I think we answered the daylights out of this one .I wonder if they'll come back to see
由完成的
@jimfixer , @oldturkey03 , Yep. sometime's, I could be researching or writing/editing on an answer, go to post and it has been answered 3X.
由完成的
@jimfixer @lpfaff1 Gentlemen great minds think alike!
由完成的
添加一条评论
添加你的答案
Lupe Ramitez 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 43
总计 10,085
