跳转到主内容
Compact digital camera with built-in flash with 10.0 Megapixel, 10x Optical Zoom and Image Stabilizer System. Disassembling requires the use of certain equipment.
19 个问题 查看全部
SD Card slot issue
The SD card will not stay in the slot. It no longer clicks into place. Has anyone ever repaired/replaced this part?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
JillEMoody , Check the video link below, you may have a small piece of debri inside the SD slot not allowing card pin to lock in card. If you do probe inside the slot be careful not to damage any of the readers contacts(very delicate). Good luck.
https://www.youtube.com/watch?v=ZgTK5g_j...
这个答案有帮助吗?
得分 3
2条评论:
Thanks, but I think the spring is the issue. There's nothing in the port, and when I press the lever with a screwdriver it doesn't latch. Looks like I'm going to have fun taking the camera apart to see if I can find the broken spring.
Using my cell phone to light up and zoom in was useful.
完成的
JillEMoody, The link/ guide partial tear down, below may help you take apart camera to access card port. Good luck with your device.
Canon PowerShot SX120 IS Screen Replacement
完成的
添加一条评论
It sounds as if you are putting the card in upside down. Try flipping it around. I hope this helps.
这个答案有帮助吗?
得分 0
4条评论:
No, that's not the problem. You can't put the card in upside down in this camera, it doesn't fit that way. When I press down the card, it pops right back up. I've tried two cards, but neither will stay inserted.
Thanks, anyway.
完成的
Hmmm... The spring that holds it in must have been knocked out of place. Try opening the camera up and taking look.
完成的
Yes, that seems to be the issue. Thanks.
完成的
Good. I'm glad I could be of help.
完成的
添加一条评论
添加你的答案
JillEMoody 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 351
