跳转到主内容
Repair and disassembly guides for Samsung DVD players.
DVD player reads some discs but stop reading and playing others
My Samsung DVD player makes loud noises while playing certain discs bit runs smoothly with others. It also freezes in the middle of playing certain discs but plays others all the way through with no problem. It has recently completely stopped reading and playing certain discs that were playing fine before. What could be causing this issue? Is it time to replace it? It was given to me by my sister. I don't think she's had it longer than a couple years.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 6
3条评论
My toshiba will play sequential chapters in a professionally cleaned disc and then refuse to start the next chapter. Disc clean as a mirror.
完成的
my dvds and cds are not working properly there's a buzzing sound inside my combi
完成的
My Samsung DVD surround sound will play blue ray ok. But all of the sudden it won't play older dvds that it used to play. Only half the sound plays on them. I can hear songs but not conversations. Frustrated ?
完成的
添加一条评论
2个答案
已选择的解决方案
@anncan , Belle, Most people do not realize DVD player like most devices require servicing/cleaning once in a while. So before throwing it away try giving it a good cleaning, below are some guides that will show how to remove the DVD players case and how to clean to help eliminate problems. Also it should be noted that DVD's can degrade over time, especially when not stored properly, the last link gives a good explanation of this. Try your DVD disc that are giving problems in another player to rule out damaged disc. There are also DVD cleaning kits available at almost any store that sells DVD,s that you could try, they will not clean as thoroughly as seen in the links though. Good luck.
http://www.dummies.com/home-garden/home-...
Cleaning Samsung DVD-P230 Laser Lens
https://www.youtube.com/watch?v=9NwX8-oT...
http://dvd-players.wonderhowto.com/how-t...
https://www.lifewire.com/what-is-dvd-rot...
这个答案有帮助吗?
得分 7
1条评论:
Thanks! I figured it most likely needs a cleaning. I hope it's not wearing out. It doesn't have that burning smell that my old broken one had when I tried to play a disc though so maybe there still is hope. :)
完成的
添加一条评论
I have dvd r discs not reading on my DVD player what do I do
这个答案有帮助吗?
得分 0
2条评论:
Removing the thin greacy layer from the inner surface of DVD's can be useful.
Use water and Dishwashing Liquid( one drop).Gently rub them with your fingers.
If you cannot use water ,use alcohol:
Place the disc label-down on a soft cloth, and spray the disc with isopropyl alcohol. Use a microfiber cloth to wipe the alcohol over the surface of the disc in straight lines until it is completely coated with the alcohol
完成的
I have had similar problem with an Alba make.
It now won't play any disc.
I have taken it apart it looks quite clean, with little dust.
I gave the lense on the laser a clean. I wiggled a pushed at any plugs I could get at.
I don't know what else to do?
完成的
添加一条评论
添加你的答案
Belle Blodgett 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 13
过去 30 天: 53
总计 89,636
