跳转到主内容
Released in July 2008 by Acer Inc., this netbook can be identified in the ZG5 Acer Inspire One family with the model number A150-1672.
3 个问题 查看全部
My computer is frozen and unresponsive.
Randomly my computer froze and the mouse won't move on screen. I can't pull up the task manager or get anything to happen. When I press the power button, it will go to a black screen, but when I hit it again, it comes back to the same frozen screen.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
student question
完成的
My CP is stuck frozen how do I get it unfrozen
完成的
添加一条评论
4个答案
已选择的解决方案
The computer may be taking in too much input or there could be a malfunctioning program or application.
Since you can't restart the computer on-screen, the best way to fix this is to do a hard reset by either holding down the power button until the computer totally shuts off, or by removing the battery.
After this, it may also be good to do a system restore to a time before your computer froze to make sure that there weren't any changes to your computer that caused the freeze.
这个答案有帮助吗?
得分 1
添加一条评论
My pc doesnt work when i turn it on my mouse doesnt move on screen restart it and the pc is still frozen please whoever fixes this I need help.
Thank You
这个答案有帮助吗?
得分 1
1条评论:
What if its a new one without a battery?
完成的
添加一条评论
Remove the battery if you can, and if the device has a CMOS battery, remove that for 10 seconds. Replace both.
If you still get the same results, you may want to try replacing the hard drive, as I see this as a plausible reason for these symptoms.
这个答案有帮助吗?
得分 0
2条评论:
How do I for sure get it unstuck
完成的
This is a new CP how can the hard drive be bad
完成的
添加一条评论
Control + Alt + Delete and restart.
I’ve had this problem a couple of times, but this always fixes it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Connor Watkins 将永远感激不已
浏览统计数据:
过去 24 小时: 8
过去 7 天: 39
过去 30 天: 211
总计 26,646
