跳转到主内容
加入维修社区 - 创建账户
电动及燃气高压喷射清洗机(有时也被称为压力清洗机)的维修指南和支持。
Not firing when trying to crank
My power washer does fire when I try and crank it
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
gailfeltman what make and model is it? What do you mean by "washer does fire when I try and crank it"? It fires up? It comes on fire?
由完成的
添加一条评论
2个答案
已选择的解决方案
gail, trouble shooting pressure washer small engine will not fire. You will have to test the engine for fuel/air/spark/compression and see what is missing/faulty. Check the attached links,instruction and guides, Good luck
http://www.repairfaq.org/samnew/lmfaq/lm...
https://www.briggsandstratton.com/na/en_...
http://www.jackssmallengines.com/diy/tro...
http://www.repairclinic.com/RepairHelp/H...
http://farmforum.ca/article/diagnose-sma...
这个答案有帮助吗?
得分 5
添加一条评论
Check Sparkplugs for loose wire, dirty connection, or debris. Spark plugs on small equipment can also break pretty easily since they are exposed.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
gailfeltman 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 14
总计 400
