Not firing when trying to crank
My power washer does fire when I try and crank it
gail, trouble shooting pressure washer small engine will not fire. You will have to test the engine for fuel/air/spark/compression and see what is missing/faulty. Check the attached links,instruction and guides, Good luck
http://www.repairfaq.org/samnew/lmfaq/lm...
https://www.briggsandstratton.com/na/en_...
http://www.jackssmallengines.com/diy/tro...
这个答案有帮助吗?
Check Sparkplugs for loose wire, dirty connection, or debris. Spark plugs on small equipment can also break pretty easily since they are exposed.
这个答案有帮助吗?
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 5
总计 102
1条评论
gailfeltman what make and model is it? What do you mean by "washer does fire when I try and crank it"? It fires up? It comes on fire?
由 oldturkey03 完成的
