跳转到主内容
The Inspiron 15-3521 has an optional touch screen feature and has a 15.6" display. This laptop is also complete with a matte finish and keyboard complete with number pad.
20 个问题 查看全部
unable to turn it on
i have a problem with my laptop "dell inspiron 3521" when i press on power button nothing is happening there is no response , and when i connect the adapter , the led of the adapter starts to blink and stops when i disconnect the adapter from the laptop
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
Waleed Hamdy have you checked teh output of your AC adapter? Is it the right voltage for your Dell? what else have you tried? How long has this been going on?
完成的
since yesterday my laptop is not working it happened suddenly , i think the adapter is working well as i have tried another adapter and it had made the same blinking on connecting it to the laptop
完成的
Try to remove the battery, the AC adapter and tyour RAM memory. Then push and hold down the power button. Do so for a few minutes. Then replace the battery and one memory module as well as the AC adpater and see if it shows anything.
完成的
添加一条评论
1个答案
已选择的解决方案
Waleed, As oldturkey suggest try a reset. From post in another forum I read, possible it could be a faulty/worn out battery. Check link below. Hope it helps, Good luck.
http://www.geekstogo.com/forum/topic/340...
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Waleed Hamdy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 168
