跳转到主内容
Released December 3, 1994 in Japan and September 9, 1995 in North America. Models SCPH-100x, SCPH-3000, SCPH-3500, SCPH-500x, SCPH-550x, SCPH-700x, SCPH-750x, and SCPH-900x.
Spinner Hub Making Grinding Noises and Not Reading
Hi, well I have a SCPH-5501 Playstation and for some odd reason the Spinner Hub wont read my disks (therefor going to the menu after the SONY logo appears) and makes a grinding like noise. Also, when I try touching the spinner it doesn't make complete spins as a normal playstaion would. Plus, I did put some Vaseline underneath the Hub were it looks like a small corkscrew and still nothing.Though, I'll be happy if anyone could help me with this situation.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
8个答案
已选择的解决方案
This is a very common failure on the grey PS1. This is either caused by a all plastic laser, or a faulty optical block. The die cast ones fail from optical block failure and the plastic ones wear unevenly. Adjustment can help, but it doesn't last forever and it's not a super reliable way to fix the problem. It works, but it's only recommended if you have nothing left to lose.
My recommendation is to get a SCPH-10x unit. It isn't prone to this problem, but the Parallel/Serial ports are no longer on these units. Most people do not need them, but if you do get one of the early 700x models.
If you choose to adjust it, there's a point on the motherboard and the laser assembly. You will need an oscilloscope to adjust the board trimpot, and for the laser trimpot do it in small doses until you get a near 100% hit rate.
Messing with the board one is NOT RECOMMENDED. You do not have to adjust it so leave it alone. You want to adjust the one on the laser. It isn't as effective but it's a lot safer to adjust then the motherboard point is.
Now if you are brave and are willing to risk it, mess with the one on the motherboard. You will risk burning your games but it does work a lot better then the one on the laser assembly. You can follow this guide on how to adjust the laser, which explains how to do it.
PlayStation Optical Drive Replacement
PlayStation Optical Drive图片
指南
难度:
中等
10 - 20 minutes
PlayStation图片
指南
PlayStation SCPH-5501 Motor Speed Adjustment (KSM-440ADM/AEM+)
难度:
困难
1 - 3 hours
这个答案有帮助吗?
得分 3
1条评论:
Get the optical drive for/from SCPH-101 and install into SCPH-5501 using a ribbon cable extension.
完成的
添加一条评论
you can buy a new spinner and thake the old one and it may work
这个答案有帮助吗?
得分 0
1条评论:
It sounds like they were talking about the gear on the optical drive. But yes, the spindle hub, and spindle motor can be replaced. A better dealer of hubs will sell you a spacer tool.
完成的
添加一条评论
sorry new here, but I'm having a similar issue with a psx that I recently bought at a second hand shop, does the exact same thing and and nothing shows up on screen, no PlayStation logo, no menu, nothing at all. could it be that I still need to replace the entire optical assembly?
这个答案有帮助吗?
得分 0
1条评论:
More info needed.
完成的
添加一条评论
see, i had the same thing happen to me tonight. the lasar reader wouldn't move so it kept taking me back to the main menu. Weird thing was, it worked only a few months earlier! I was able to play a cd in it just fine! Could the lasar reader just be stuck?
这个答案有帮助吗?
得分 0
添加一条评论
alright I got another question: I already bought a new laser pickup and replaced the old one, however I'm still having the same issue, any idea what the issue might be at?
这个答案有帮助吗?
得分 0
添加一条评论
Hi there,
I'm having the same issue, and bought a new optical drive to replace the original: same issue. This doesn't seem to come from a faulty optical drive.
Any ideas ?
这个答案有帮助吗?
得分 0
添加一条评论
Replace the spindle hub. All you need to do is dig up an old portable cd player(or make a trip to a thrift store),CAREFULLY pry the spindle hub off of the cd drive, and slide it onto the metal post on the psx cd drive after you remove the old spindle hub. I had that problem and now the cds dont skid.
这个答案有帮助吗?
得分 0
添加一条评论
The SCPH-5501 models have this problem, that is why they redone the PlayStation three different times. The later PlayStation models doesn’t have this problem. You can find a later model on Ebay or Amazon for a reasonable price.
这个答案有帮助吗?
得分 0
1条评论:
Nah, my SCPH-5501 works best, but I installed the optical drive from a SCPH- 101 using a ribbon cable extension.
Many possible issues. Semiconductors, ICs, power...
完成的
添加一条评论
添加你的答案
FatalChomper 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 18
过去 30 天: 58
总计 18,120
