跳转到主内容
加入维修社区 - 创建账户
PlayStation Optical Drive Replacement
你所需要的
  1. PlayStation Optical Drive Replacement, Open the Console: 步骤 1 中的图像 1,1
    • Before you begin, make sure the console is turned off and unplugged.
    • Turn the console upside down and remove the five 15.8 mm-long Phillips #1 screws.
    添加评论
  2. PlayStation Optical Drive Replacement: 步骤 2 中的图像 1,2 PlayStation Optical Drive Replacement: 步骤 2 中的图像 2,2
    • While holding the top and bottom halves of the console together, flip the console back over. Lift the top cover straight up to remove it.
    询问修复机器人
    添加评论
  3. PlayStation Optical Drive Replacement, Remove the Optical Drive: 步骤 3 中的图像 1,2 PlayStation Optical Drive Replacement, Remove the Optical Drive: 步骤 3 中的图像 2,2
    • Pull the optical drive power cable straight up and out of its socket on the motherboard to disconnect it.
    添加评论
  4. PlayStation Optical Drive Replacement: 步骤 4 中的图像 1,3 PlayStation Optical Drive Replacement: 步骤 4 中的图像 2,3 PlayStation Optical Drive Replacement: 步骤 4 中的图像 3,3
    • Use the flat end of a spudger to lift up and unlock one side of the data cable's connector on the motherboard. Repeat this step on the other side of the connector.
    • You'll hear a faint click noise when unlocking the connector. Make sure not to apply too much pressure when lifting up on the connector with the spudger, or else damage may result.
    • Gently pull the optical drive data cable straight up and out of its socket on the motherboard to disconnect it.
    添加评论
  5. PlayStation Optical Drive Replacement: 步骤 5 中的图像 1,2 PlayStation Optical Drive Replacement: 步骤 5 中的图像 2,2
    • Lift the optical drive straight up to remove it.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
56等其他人完成本指南。
Craig Lloyd
于02/10/16注册
42,966 声望
创作了82篇指南
5指南评论
Laser Drive Models
SCPH-100x : KSM-440AAM and KSM-440ACM
SCPH-550x-700x : KSM-440ADM
SCPH-750x-900x : KSM-440AEM
SCPH-10x : KSM-440BAM
Chances are most, if not all of the original AAM and ACM lasers are worn out.
Some vendors still carry an supposed original KSM-440BAM laser unit only.
I could not make this laser work in a SCPH-1001 unit, even after the transfer of parts.
I heard a rumor of spacers and motherboard adjustment.
This: https://web.archive.org/web/201010090109...
PU-8 test point: CL708, voltage reading to ground without disk - 1.7 volts DC, voltage reading with disk 1.85 volts DC.
Very fine adjustment… I have yet to try this step. Has anyone?
What about spacers? Do I need these?
You must transfer the rubber grommets and the plastic laser cover from the old laser to the new.
If you don’t, the new laser will be too large for the SCPH-1001 chassis.
leafybye - 回复 分享
What about model SCPH-5501?
janis Nasuta - 回复 分享
Will a KSM-440BAM optical drive from a scph-1001 ps1 work with a scph-1001 ps1 that had a KSM-440ACM optical drive?
The invader 2 - 回复 分享
Hello! Has anyone had success with replacing the optical drive on a 1001?
If so, which model of drive was used?
John Reeves - 回复 分享
which optical drive do you recommend on SCPH-1002?
Juan YT - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 12
过去 7 天: 135
过去 30 天: 596
总计 77,283
