跳转到主内容
The Canon PowerShot SX160 IS is a 16.0 megapixel digital camera with a 16x wide-angle optical image zoom and a 3.0 inch LCD.
Why does my camera not hold the date and time?
EVERY time I turn on my camera a screen comes up asking me to set a date and time. I do so, it says the date and time is as I set it. However, when I turn it back on the same screen comes up. When pictures are downloaded in my computer. the time is set to 1980!!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 33
11条评论
can you help me set them time on my canon powerShot SX160IS?
完成的
Glad to have found the answer - I didn’t even know there was a battery there!
完成的
Thank you!! This was starting to annoy me.. Fixed on my powershot s5is, battery was tucked away beside my other battery's.. Didn't even know it was there
完成的
The date /time battery compartment is right beside the 3rd AA battery in the camera. It says CR1220 - that is the size of the tiny battery that goes in there. Hope this helps.
完成的
Thanks! I figured it out finally.
完成的
显示更多的6条评论
添加一条评论
6个答案
已选择的解决方案
@darla this is common once the RTC (real time clock) battery is depleted. your camera will not remember the time and date without this battery. Changing it by using this guide should resolve this issue.
这个答案有帮助吗?
得分 40
15条评论:
Great. They should have put a memo in the box with the camera. Thanks.
完成的
It's been so long since I've used my A540 that I'd completely forgotten about the RTC battery, but that's what the problem was, all right. Thanks for the reminder!
完成的
I've done this and it's still not working. Any other suggestions?
完成的
When you say "not working," do you mean it still asks for the time and date even after you've replaced the battery? I can only suggest that you make sure the battery is fresh and that you insert it right side up. If the camera works otherwise, I can't think of what else it might be.
完成的
Yes, I meant the date and time still do not work. I've checked the battery with a voltage meter and it definitely works. I've reinserted the battery multiple times, looking at the pictures above and other sources.
I'm stuck.
完成的
显示更多的10条评论
添加一条评论
Had the same problem with my Canon Powershot SX20 IS. Found this little battery compartment that holds the CR1220 on the bottom of the camera inside where the main batteries are installed. Just open the bottom battery compartment and you will see the small little part you need to slide off. You may need a small flathead screwdriver. Hope this helps someone else out there.
这个答案有帮助吗?
得分 11
7条评论:
Different Camera - Powershot A1200 - but this is exactly the relevant Information. Thx!
完成的
THank you very much! I had this same problem and just thought I camera was done for! problem solved!
完成的
Well thnx lol sitting here getting frustrated
完成的
Thanks for this. Is that even in the manual? No idea/
完成的
完成的
显示更多的2条评论
添加一条评论
Try changing the tiny battery on the left side, on the top, pry open w/ your fingernail and replace this. I found this info doing a search online mine said CR-1220, its like a button battery, hope this works for you!
这个答案有帮助吗?
得分 5
4条评论:
I replaced the battery. It still does the same thing.
完成的
OK. The battery must be inserted into the guide flat down. Now it works.
完成的
This works for the A520 and probably other A510 series. That battery has lasted for 15 years!
完成的
Thanks yes it was the RTC
完成的
添加一条评论
I happen to have this exact same model camera and the same problem! To think, I only searched for Canon camera date reset in Google and it brought me right here!
It does appear the problem is the CR1220 button battery needs to be replaced. I think these can be found at most drug stores.
这个答案有帮助吗?
得分 1
1条评论:
I found a replacement battery ok but it still won't save the date and time!
完成的
添加一条评论
这个答案有帮助吗?
得分 1
2条评论:
The image is our old ps sx20
完成的
Thanks for your suggestions I am about to buy a new one. It’s help me to change the lithium battery.
Thanks again
完成的
添加一条评论
I bought the battery t london drugs with tax like 10 bucks they said camera was older but they still caried that brand battery no problm in getting them,
and when i chnged it my time and date stayed set after i shut it off then on again,
problem solved
这个答案有帮助吗?
得分 0
2条评论:
Will it work for model Power Shot A460?
完成的
Can one change the built-in date/time battery in a Canon IXUS 185?
完成的
添加一条评论
添加你的答案
Darla Hare 将永远感激不已
浏览统计数据:
过去 24 小时: 19
过去 7 天: 95
过去 30 天: 473
总计 86,683
