跳转到主内容
The Xbox 360 is the second game console made by Microsoft, and was released November 22, 2005.
428 个问题 查看全部
Will the RROD kit fix this xbox?
Hey everyone. So sometime last year my brother gave me his old xbox that has had the RROD forever and it was just sitting around. I tried taking it apart and it literally looked almost brand new inside with hardly any dust. I took off the heat sinks and there was like no thermal paste at all. Could that be what was causing the RROD and will the fix kit fix it with that problem? Thanks for anyones help!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
3个答案
已选择的解决方案
CitrusHD, you could try the RROD fix kit from ifixit. The kit is strictly providing additional pressure on the GPU/CPU to try to close cracks in the solder joints ( as well as reconnecting the bumbs, long story). You most likely have issues with your GPU processor. It is a flip chip design and the issue could be the solder bumps between the IC and the substrate.. Combining this with a reflow with a heat gun may just complete a good repair. Check on here step 49 will explain it. Check on here for the reflow guide. Also "remember that all that this kit is trying to accomplish, is to close cracked solder joints. Most of the time the extra few pounds of torque provided by the kit, will close those cracked joints. It is not a permanent fix, nor is it a sure thing either. It all depends on the individual logic board and the damage to the solder joints as well as the chip itself I strongly suggest a reflow with this kit. The chances to be successful is greater with a combination of RROD kit and a reflow. Of course, a permanent fix would be a total reball. for a reball to be done, you will need the stencil, a rework machine as well as the proper reball temperature template, and a new processor. If you do not have those tools, you can not do a reball. In that case you need to find somebody that will do the repair for you. Yes, you do want to replace the thermal paste as well. Contact the game console guru on here and see if he can help you out.
Update (02/27/2016)
Citrus HD here is a very "quick and dirty" explanation of what causes most of the RROD. It is not always a failure of the solder balls which connect the Flip Chip BGA package to the motherboard. It does happen and you can see why [ http://www.bunniestudios.com/blog/?p=223|on here] More commonly however is that the failure is due to the chip design itself.
As you can see the "bumps' are what actually connects the die to the substrate to make the chip complete. If these bumps fail the die does no longer make contact either he substrate and thus no contact with the circuit board. The chip has failed.
Here you can see the space where the bump has failed and no longer makes contact. We are talking microns of space here. So a bit of pressure on the top of the die potentially close the gap. Same with a reflow, it may allow some of material from the bump to reshape and starting to make contact again. The heating of cooling of the chip during use is what will eventually cause it to fail again.
Xbox 360 Red Ring of Death Fix Kit图片
指南
难度:
困难
45 minutes - 1 hour
Xbox 360图片
指南
Reflowing Xbox 360 Motherboard
难度:
困难
1 - 3 hours
这个答案有帮助吗?
得分 3
1条评论:
Thank you so much for this good explaination!
完成的
添加一条评论
Hi citrus, the rrod in xbox360 is typically caused by a solder ball under the gpu or cpu that doesn't make a good contact with the motherboard. The kit you're talking about just makes more pressure over the chip so the contact that is not working hopefully starts to work again. The fact that you didn't find any thermal paste is very unlikely, the reason you didn't find it I think it's because somebody already tried to fix it. You can try the kit since that is not expensive but I can already tell you that if it luckily starts working again it won't last for a long time. If you're interested you're probably going to need a reball done by a technician and I think they will ask you 40-60$, but that's the real fix for the problem. Bye.
这个答案有帮助吗?
得分 1
1条评论:
Hi, I know for a fact that it has never been worked on before me opening it. Would you still say the same thing?
完成的
添加一条评论
The fix kit should fix your xbox
这个答案有帮助吗?
得分 0
1条评论:
Why would the kit fix it?
完成的
添加一条评论
添加你的答案
CitrusHD 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 16
总计 1,215
