跳转到主内容
GSM iPad 2 with 16, 32, or 64 GB of storage, and a Dual Core A5 Processor. Model Number A1396. Repair is complicated and requires heat and prying.
iPad2 16 GB Screen blank. Cannot boot.
iPad2 16 GB not booting.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论:
jttowner, what have you tried? did anything happen to the iPad? Have you charged it on a proper charger?
完成的
添加一条评论
1个答案
Try a new charger & cord, look for visible damage to the charge port or corrosion. Do a hard reset, hold power and home button at the same time. The Apple logo should pop up after about 10-20 sec.
If all that doesn't work you would need to disassemble the iPAD and disconnect the battery for about one minute and then reconnect. You can have a local repair shop do this for you if your not comfortable.
If that doesn't work there is a board level issue and it might not be economical to repair.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jttowner 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 88
