iPad2 16 GB Screen blank. Cannot boot.
iPad2 16 GB not booting.
Try a new charger & cord, look for visible damage to the charge port or corrosion. Do a hard reset, hold power and home button at the same time. The Apple logo should pop up after about 10-20 sec.
If all that doesn't work you would need to disassemble the iPAD and disconnect the battery for about one minute and then reconnect. You can have a local repair shop do this for you if your not comfortable.
If that doesn't work there is a board level issue and it might not be economical to repair.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 87
jttowner, what have you tried? did anything happen to the iPad? Have you charged it on a proper charger?
由 oldturkey03 完成的
