跳转到主内容
Why is Bluetooth is unavailable when I check profiler?
I replaced the dc in as well as the frame around the LCD; everything was a success however when I checked the profiler the bluetooth was no longer available. My question is where is the bluetooth antenna/chip or whatever it is on this computer? I have it open but im not seeing anything that would appear to be wires I forgot to connect. Thanks for any help
Ibook G4 1.33 14" A1055
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Go to this teardown and look in the upper left hand corner for the bluetooth board and cable: http://ep.yimg.com/ca/I/lovemacs_2119_29... The cables run right next to each other in the upper left hand corner and you may have disconnected something.
这个答案有帮助吗?
得分 1
1条评论:
From this diagram does it look as though the antenna runs up the side of the lcd or does it stay in the upper case area?
完成的
添加一条评论
添加你的答案
mike36 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 912
