跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy Grand Neo 于 2014 年 2 月发布。这是一款 5.01 英寸显示屏的中端智能手机,且有一个双 SIM 卡版本。GT-I9060I 型号被称为 Samsung Galaxy Grand Neo Plus。
Falling in the water
Hello everyone.
Two days ago my phone falls in the water. I tried to dry it up with hair dryer and also i left it for two night in a dry place.
Yesterday it works and when I turn on my mobile, it displayed a notification that is enabled the safe function. Το disable this function click here and the device will be restarted. After this all the applications will be available. When the device restarted it displayed the same. Also when I charge the device with or without battery the flash turns on. Is there anybody who can help me to solve these problems.
Thank you very much.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
bellonig23 the issue here is that you will need to clean your phone. For as long as you have not cleaned it, you are running risk of shortening out your phone even further and causing increased damage. I would suggest that for the time being you do not try to charge it, or to turn it on. Disassemble it using this video. Then clean it properly with isopropyl alcohol. Use this guide to see how to clean it. It was written for an iPhone but all the points are still pertinent to your phone as well. Once you have it cleaned properly, you must replace the battery. then reassemble and re-evaluate for residual damage.
这个答案有帮助吗?
得分 0
添加一条评论
Did it work.
Mine's victim to Burmese water festival.
Grrr...!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
bellonig23 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 974
