跳转到主内容
Product released in 2011. Portable on-ear headphones that come with a detachable audio cable with built-in remote and mic for iPhone/iPod/iPad connections, and a carrying case.
22 个问题 查看全部
cant get pins out to replace headband
Hello!...I am trying to replace the headband on my boys Beats Solo HD and I cant seen to get the pins out. It appeared while looking at it on vid that they actually fell out....not mine of course!.I am patient so before i go further I thought I would see if I could get help here. All is going great accept for this problem. I would be grateful if there is a way or trick to get them out. Thanks very much in advance for reading.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
2个答案
最有帮助的答案
See if this guide helps: Beats Solo HD Right Hinge Pin Repair
这个答案有帮助吗?
得分 1
3条评论:
It's telling me I don't have access to this link. Is the link private ?
完成的
Well that's not right. Can we get some help here? @kelsea
Kelsea, are you sure you wanted this job?
完成的
Just made it public! @mayer I'm a ride or die iFixit-er. I'll be here for the long haul. ;-)
完成的
添加一条评论
Spray the pins and hinge with some lube, then tap, fairly hard with the end of a screw driver and the pins will fall out or stick out far enough to grab with tweezers.
Don't be afraid to hit it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
done4fun 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,763
