跳转到主内容
加入维修社区 - 创建账户
洗碗机 的维修指南、手册和故障排除帮助。获取自己维修 洗碗机 所需的一切。
lights flashing nothing wprks
Our whirlpool quiet partner ii dishwashers HEATED WASH, NORMAL, AND CANCEL lights were flashing when we got up this morning. Worked fine yesterday. Tried going through the reset cyle and umpluggong it and going back through reset. At a loss for what to try next any advice?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
My whirlpool 2011 has cancel light flashing
完成的
添加一条评论
2个答案
已选择的解决方案
duane, try to reset your dishwasher first. To reset it, you will have to have the door open. It can not be latched. Press "Heated Dry," "Normal," "Heated Dry," "Normal" within three seconds of the first pressed button. Now close the door, this should reset your dishwasher. For some of the newer dishwasher, those that do not have dedicated 'heat dry' and 'normal' buttons, you push any 3 buttons in the following sequence: 1-2-3-1-2-3-1-2-3, with no more than a second between each button push. That will put the dishwasher in diagnostic mode. Let us know what you get and what exact model your DW is.
这个答案有帮助吗?
得分 2
1条评论:
This worked for my Whirlpool dishwasher after I had tried everything for two days! Thank you.
完成的
添加一条评论
Afternoon all, I have trying that exact solution for the same problem for the same dishwasher model type.
The "Heater Dry" lights up, but not the "Normal". Other lights that show up are "Pots/Pan", "Rinse","Sani-Rinse", "Heater Dry".
When I push the "Cancel/Drain", you can hear the motor runs.
Not sure if I will need to replace the panel, since the lights on "Normal", and "Light" have are not turning on at all
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
duane 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 77
总计 15,713
