跳转到主内容
加入维修社区 - 创建账户
Removal and Install ac Compressor
removal of ac compressor
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
1个答案
已选择的解决方案
Purcell Hamilton, first you want to make sure that you get the refrigerant removed from the AC.
Remove the drive belt
Loosen the bolt securing the drive belt.
Loosen the adjusting bolt and remove the drive belt.
Remove the compressor.
Disconnect the electrical connector from the compressor.
Remove the two bolts holding the liquid line and discharge line to the compressor.
Disconnect the lines from the compressor by pulling them out.
Remove the four bolts holding the compressor to the engine/support bracket.
The compressor can now be removed.
Install in reverse order. Remove that you will need to have the right amount of compressor oil added to the compressor and that you need a vacuum pump on the lines to make sure that all humidity etc. is removed.
Decent video right here should help.
这个答案有帮助吗?
得分 6
4条评论:
Does this method apply to the 2004 Mitsubishi outlander?
由完成的 分享
scain81dt the compressor removal is identical. The differnce is that the drivebelt is differnet and needs to be removed slightly different.
由完成的 分享
Ok Thanks! oldturkey03 i have rattling and i think i saw sparks coming from my ac compressor should I replace the compressor or just the clutch ?
由完成的 分享
scain81dt I'd go with what is easier to obtain. Just repalced a compressor on an F-150 and the difference in price for repalcement with clutch and without was negliable. I repalced the whole beast since I had to take it off anyway. Again, all just a mater of economics. If you want to disassemble it etc. let me know by email if you need the manual. My address is in my user profile. click on my avatar to get there
由完成的 分享
添加一条评论
添加你的答案
Purcell Hamilton 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 20
总计 12,702
