跳转到主内容
Repair guides and support for all household mechanical fans including ceiling, box, tower, and stand fans.
Lasko electric fan has no power; Stopped working
No sign of power from outlet to my fan.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
13条评论
I have a circular Lasko 18 inch fan on stand. One day I turned it on nothing, it has completely shut down. this fan is only 6months old.
完成的
I have no answer but this has happened to my fan and it is like a month old. I have another Lasko fan on a stand that is way older and still working fine. How annoying this has happened to my new Lasko fan I have to do all that work for a new fan?
完成的
I have the same problem with the fan I purchased just stopped working. I'm going to contact Lasko before I throw it away!
完成的
I have an lasko oscillating fan on stand, this fans will stop and the start again. What do I need to do to correct this
完成的
I have my lasko remote control standing fan for 6 years. In the beginning the buttons gave problems got it fix hardly used the remote. Since lately I notice the fan keep on shutting on and off. How can I fix this problem?
完成的
显示更多的8条评论
添加一条评论
6个答案
已选择的解决方案
Depends on your model, but I would unplug it and find a way to disassemble the fan to check the wiring to the fan motor and switch. Then measure the individual points to where you have power and where it stops. Could be the switch as well as an internal fuse on the fan. Again, depends on the model.
这个答案有帮助吗?
得分 3
3条评论:
Mine was working I unplugged it and it would not turn back on
No power
完成的
@dicktracy65596 time to unplug it, take it apart and check teh motor, switch and capacitors etc. All you should need is a pair of screwdrivers and a multi-meter.
完成的
My Lasko fan/air filter model 2559 stopped working. Would not power on. Took it outside and used my leaf blower to remove all the dust. It works fine now.
完成的
添加一条评论
I contacted them and they sent me a new one.
这个答案有帮助吗?
得分 2
4条评论:
Can you please give me that customer service contact info ? As the number i have i cant get thru to a human . Sucks
完成的
Me also! LOL
完成的
I had the same problem, they told me mine was too old , 2 years ??
完成的
Mine stop running after a while 1 day and light it up, but it won’t turn on
完成的
添加一条评论
mine is just over the year mark for manufacturer’s warranty and i hate throwing stuff away if i can help it anyways, so i replaced the wall plug (theirs contains a safety fuse, which blows if you press two buttons at once or in quick succession- poor design) and it works fine now. cost 3$ and a relatively simple/easy repair.
这个答案有帮助吗?
得分 2
添加一条评论
Hi @Donna Mathews,
There is a 12 months manufacturer’s warranty on the fan
Contact the manufacturer as per the details in the image shown below which was taken from the Lasko 2711 user manual about a manufacturer’s warranty repair or replacement. That’s what warranties are for.
(click on image to enlarge for better viewing)
这个答案有帮助吗?
得分 1
添加一条评论
See if the blades turn freely first. If they do, try taking it apart and checking the thermal fuse of the motor which will probably be wrapped into the coils somewhere near where the wires go in. Unfortunately it's a bit fragile since the wires are thin, so you'll probably have to exercise caution.
这个答案有帮助吗?
得分 0
添加一条评论
If your fan sudden stops working. It may be as simple as the plug itself Here is why.
If your plug has Patent written between the prongs, It likely has a hidden fuse inside the plug.....
Here is what is hidden inside the blue molded plastic plug...
An online fuse with very small limited - 2.5A which means the manufacturer did not want more current than this going into the fan PC board because I guess they didn't design it to handle more though they apparently also allow more to be "drawn" into the unit at least momentarily and then you have a paper weight for a fan because the manufacturer did not create a way to change the fuse..... as you can see in the torn apart plug in these pictures. The fuse is permanently molded into the plug with no provision for knowing if the fuse "blew" or replacing it. ( Very poor desgin from my POV ).
The Fuse details:
See Patent if you are interested in what I am talking about. The above answer about replacement the plug worked for me on a different Lasko fan.Patent LaskoPlug WithHiddenFuse
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
tomasulang2006 将永远感激不已
浏览统计数据:
过去 24 小时: 19
过去 7 天: 118
过去 30 天: 488
总计 79,962
