跳转到主内容
加入维修社区 - 创建账户
游泳池是一个装满水的容器,用于游泳或水上娱乐。
Salt Chlorinator Cell Repair
I want to find out how to repair a Salt Chlorinator Cell? It's a seemingly sealed unit with two electrodes inside which convert salt to chlorine. These electrodes get worn out or used up over time. Can these be replaced or replated? Any special tricks and things to know? Anything to be aware of so as not to mess things up? What's the worst that could happen?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
What make and model? Post some images with your question so we can see what it looks like and can may be come up with an idea.
由完成的 分享
添加一条评论
2个答案
最有帮助的答案
Most cells can be replaced every 4-5 years. Get out the install manual, it should tell you how to tear down and get a new cell that matches your model, easy fix. Get a zinc anode to help with corrosion problem, it attracts the Na ions instead of all metal parts, easy to install on ladder or plumbing and will help prolong your cell...35 years in pool biz
这个答案有帮助吗?
得分 3
2条评论:
Great idea about using a sacrificial zinc. I will be getting one for myself soon thanks.
由完成的 分享
Cyndi - are you a sailor by chance? This is how they save ships ;-)
由完成的 分享
添加一条评论
Hi!
I am also looking for a solution. Take a look at this:
http://www.philipdoolittle.com/2018/03/s...
I have 2 dead cells that I will open soon. With 2 may be I will get enough good plates to make one. My main concern is what material should I use if I have to rebuild a conneting post and how to fix it to the plate?
Richard
这个答案有帮助吗?
得分 0
2条评论:
Hi Richard,
The link domain appears to be dead.
Do you have any info and how did you go with rebuild.
Likewise I have bits but not yet sure how to connect. Spot Weld?
Brett
由完成的 分享
considering this myself, looking to source metal plates
desmetde@gmail.........com
由完成的 分享
添加一条评论
添加你的答案
Daniel Rudewig 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 41
总计 9,576
