跳转到主内容
An HTC smartphone, also known as the HTC Pico, released October 2011.
5 个问题 查看全部
Mother Board IS Dead
My HTC Explorer fell down from bike, i went to htc care they said my cell needed to replace motherboard, which cost Rs.6500.. phone's present value is 2500-3000 RS. so why should i give 6500 RS... I JUST WANT MY DATA...? ANY HELP FROM YOU ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
2个答案
已选择的解决方案
tushar, this will depend on what is broken on the board. The only way to get your data back is by trying a repair. Even if you would replace the board, you will not get your data back. It is stored on the original board.
这个答案有帮助吗?
得分 1
3条评论:
thank you... so can you please help me how to repair ??
完成的
Have you taken a look at the board to check for any visual damage. Anything broken off or any components missing?
完成的
screen is creck please repair the phone
完成的
添加一条评论
Hi tushar
it seems to be motherboard physically damaged. try to power up the phone with powersupply and connect it to pc via usb cable. if the taken power 10mA to 900mA can assume power part is working, if you already debuging mode on the device try to get data via pc. even if you cannot see anyting on the phone display PC may communicate with PC
这个答案有帮助吗?
得分 1
4条评论:
even technician said that motherboard is not working...
how to connect it with PC as cell is not even charging...
and screen is off too...
完成的
charge the cell using extranal charger and connect the device to pc and check wheater device detected or not
完成的
Bro, motherboard is dead...
phone is not working anyhow...
完成的
Oops! Try to find a good condition motherboard from eBay only if you loving to HTC exp
Advice: don’t trust the technician and all the things which they said. Better to find your own way to fix the fault.
if you do right thing your fault may solve
if you do wrong things you will have a good lesson
Cheers!
完成的
添加一条评论
添加你的答案
tushar 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 813
