跳转到主内容
The Dell Inspiron 15-7537 is a 15.6" touchscreen laptop with an i5 core processor.
20 个问题 查看全部
Why does the mousepad not work?
My computer turns on but no matter what I do with the mousepad I can't get the cursor to move.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 9
2条评论
Dont have a cursor? Can't go anywhere?
完成的
the cursor move but when I click there is no action
完成的
添加一条评论
4个答案
已选择的解决方案
Open it up and see if the battery is swollen and thus pressing on the trackpad and preventing it from being depressed.
Dell Inspiron 15-7537 Battery Replacement
这个答案有帮助吗?
得分 2
添加一条评论
最有帮助的答案
First, restart the laptop to refresh the cursor.
If that doesn't work, go to Control Panel and click on Mice and Pointing Devices. Double click on touchpad and go to Driver's Tab. Click Update Driver and RIGHT click on Touchpad select UNINSTALL.
Then, go to USB controlls and click UNINSTALL on everything except the category itself. Then reboot the machine. This should refresh the TouchPad Driver and USB stack.
Then, go to the System site and download the latest touchpad drivers. Save the file and run it as admin.
这个答案有帮助吗?
得分 4
2条评论:
You can also refer to the troubleshooting guide to diagnose the problems and find other solutions.
完成的
This works but it is only a temporary fix.
完成的
添加一条评论
I was having the same issue, but I have the Inspiron 5555. I tried EVERYTHING to fix it. Found out it was actually my touchscreen causing the issues. I had to disable the touchscreen in Device Manager, and now my touchpad is working fine. I hope this helps someone and they don’t have to spend HOURS trying everything under the sun to fix their touchpad.
这个答案有帮助吗?
得分 1
4条评论:
Hi There,
I have the same problem, but can't find this device, can you help me out?
完成的
I second hennievisscher's comment, above
完成的
That’s all wonderful but the mouse pad/curser doesn’t work so how do you suggest I accomplish all the steps you recommend in the solution ? ?‍♂️
完成的
If anyone else has a question like Paul...
Use a USB mouse, just connect it to a USB port.
完成的
添加一条评论
I had similar problem. It was my touch pad sensitivity that caused the issues as it was on high sensitivity, as soon as I decreased to medium sensitivity, as I was able to click with touchpad
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Emily Woo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 68,855
