跳转到主内容
加入维修社区 - 创建账户
Dell Inspiron 15-7537 Battery Replacement
你所需要的
  1. Dell Inspiron 15-7537 Battery Replacement, Bottom Case: 步骤 1 中的图像 1,1
    • Make sure the display is closed. Then, flip the computer over so that you can see the bottom cover.
    • Loosen the two 5 mm Phillips #0 on the upper edge of the cover.
    • These screws will stay captive to the case.
  2. Dell Inspiron 15-7537 Battery Replacement: 步骤 2 中的图像 1,1
    • Remove the two 5 mm interior screws that connect the cover to the assembly using the same Philips head screwdriver from the previous step.
  3. Dell Inspiron 15-7537 Battery Replacement: 步骤 3 中的图像 1,1
    • Use a spudger to remove the base cover from the rest of bottom cover.
  4. Dell Inspiron 15-7537 Battery Replacement, Battery: 步骤 4 中的图像 1,1
    • Remove the three 5mm Phillips #0 screws that keep the battery connected to the computer.
  5. Dell Inspiron 15-7537 Battery Replacement: 步骤 5 中的图像 1,1
    • Ground the system board by turning over the computer, opening the display, and holding the power button down for about 5 seconds before proceeding.
    • Using the pull tab on the battery, lift the battery out of the computer.
结论
4等其他人完成本指南。
Abby Schmiedt
于01/22/15注册
229 声望
撰写一个指南
团队
Cal Poly, Team 18-2, Maness Winter 2015 Cal Poly, Team 18-2, Maness Winter 2015 的会员
CPSU-MANESS-W15S18G2
4 名成员
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 37
总计 7,443
