How do I turn my screen 180 degrees?
some douche at my school completley flipped my screen upside down and now it's practically impossible to us my chromebook.Please help!!!!
ctrl+shift+reload button
这个答案有帮助吗?
this was so helpful the same happened to me and i have been stuck with it for two weeks thank you so much!!!!!!!
My attention seeking kitty changed mine :) Very helpful - It was tough doing everything with my head tilted lol
it was amazing
thank you!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
thanks to all u people
Simply hit ctrl+shift+refresh. The refresh key is the one with the spinning arrow. It'll rotate the screen 90 degrees.
这个答案有帮助吗?
it is still not working please someone help me "with no websites"
You are the best!! Thanks a million!!
holidayfun1943@gmail.com
On an acer chromebook you have to hit the ctrl key, the shift key and the refresh button at the same time and that's it! I've had this happen last friday and I called the kid a douche bag so when he saw this today he thought that I did it to get back at him or something I am not sure what he meant when he showed me but I do know when he did he kept laughing at me until he showed me so. I hope this was helpful. By By
April 25, 2016
这个答案有帮助吗?
Press ctrl shift and the refresh button at the top this will only rotate your screen 90 degrees so you will keep having to do it until your CB is back to normal
这个答案有帮助吗?
omgg...THANK YOU SO MUCH
You need to press CTRL + ALT and aero botton on your computer then it will make your screen default.
这个答案有帮助吗?
thats for a different computer not chromebooks
What is the aero botton? Do you mean the arrow button? and if so, which arrow?
All you have to do is hit these
three buttons simultaneously:*
ctrl
shift
reload
*at the same time
这个答案有帮助吗?
it worked
yessssssssssss
Do you fix my Chromebook screen please
I need your help today
bem boom bech bum italic text eat my big bum == Heading text == heck
这个答案有帮助吗?
beembold text bom
i'm the douche heheh heck xd dab
It's not working what button is the refresh button
这个答案有帮助吗?
the circle arrow on top row on cromebook
circle arrow right besides the arrows
Just yell Reeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee and it will flip back around
这个答案有帮助吗?
no don’t do that
To fix your upside-down Chromebook screen, press Ctrl + Shift + Refresh (⟳) twice to rotate it 180 degrees back to normal. If that doesn't work, go to Settings > Device > Displays, then set the screen orientation to Standard. Your screen should return to normal!
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 22
总计 217,569
13条评论
It's quite simple. Use the keys ctrl+shift+refresh (The circling arrow on the top row) two times, it'll reset the screen back to 0 degrees. This is late, but just in case you need to know. If you can find a way to keep it at 0 degrees, that'd be awesome!
由 Bradford Seabury 完成的
To set the screen in its correct (default) position:
Log in as admin -> hit ctrl, alt and the left aero (<-) beside escape.
...done.
由 Michael Vovaris 完成的
Go into settings then display settings. Change screen to standard.
由 Maria Smith 完成的
hi hi hi hi hi hi hi hi hi hi hi
由 Maykala Crites 完成的
Just flip it
由 Brandon Gross 完成的
显示更多的8条评论
