跳转到主内容
The Acer Chromebook C710-2847 is part of Acer's line of low-price netbooks running Google's Chrome OS. The devices are simply constructed needing just one screwdriver to take them apart.
How do I turn my screen 180 degrees?
some douche at my school completley flipped my screen upside down and now it's practically impossible to us my chromebook.Please help!!!!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 82
13条评论
It's quite simple. Use the keys ctrl+shift+refresh (The circling arrow on the top row) two times, it'll reset the screen back to 0 degrees. This is late, but just in case you need to know. If you can find a way to keep it at 0 degrees, that'd be awesome!
完成的
To set the screen in its correct (default) position:
Log in as admin -> hit ctrl, alt and the left aero (<-) beside escape.
...done.
完成的
Go into settings then display settings. Change screen to standard.
完成的
hi hi hi hi hi hi hi hi hi hi hi
完成的
Just flip it
完成的
显示更多的8条评论
添加一条评论
16个答案
已选择的解决方案
ctrl+shift+reload button
这个答案有帮助吗?
得分 57
17条评论:
this was so helpful the same happened to me and i have been stuck with it for two weeks thank you so much!!!!!!!
完成的
My attention seeking kitty changed mine :) Very helpful - It was tough doing everything with my head tilted lol
完成的
it was amazing
完成的
thank you!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
完成的
thanks to all u people
完成的
显示更多的12条评论
添加一条评论
Just use the ctrl+shift+the reload button
这个答案有帮助吗?
得分 24
1条评论:
its not woking
完成的
添加一条评论
Simply hit ctrl+shift+refresh. The refresh key is the one with the spinning arrow. It'll rotate the screen 90 degrees.
这个答案有帮助吗?
得分 20
2条评论:
it is still not working please someone help me "with no websites"
完成的
You are the best!! Thanks a million!!
holidayfun1943@gmail.com
完成的
添加一条评论
这个答案有帮助吗?
得分 16
2条评论:
not working for me
完成的
not working for me
完成的
添加一条评论
ctrl+shift+rotate=flip
这个答案有帮助吗?
得分 14
添加一条评论
On an acer chromebook you have to hit the ctrl key, the shift key and the refresh button at the same time and that's it! I've had this happen last friday and I called the kid a douche bag so when he saw this today he thought that I did it to get back at him or something I am not sure what he meant when he showed me but I do know when he did he kept laughing at me until he showed me so. I hope this was helpful. By By
April 25, 2016
这个答案有帮助吗?
得分 11
添加一条评论
Press ctrl shift and the refresh button at the top this will only rotate your screen 90 degrees so you will keep having to do it until your CB is back to normal
这个答案有帮助吗?
得分 11
1条评论:
omgg...THANK YOU SO MUCH
完成的
添加一条评论
hit the refresh butten.
这个答案有帮助吗?
得分 8
1条评论:
no this did not work
完成的
添加一条评论
这个答案有帮助吗?
得分 6
添加一条评论
You need to press CTRL + ALT and aero botton on your computer then it will make your screen default.
这个答案有帮助吗?
得分 4
2条评论:
thats for a different computer not chromebooks
完成的
What is the aero botton? Do you mean the arrow button? and if so, which arrow?
完成的
添加一条评论
All you have to do is hit these
three buttons simultaneously:*
ctrl
shift
reload
*at the same time
这个答案有帮助吗?
得分 4
3条评论:
it worked
yessssssssssss
完成的
Do you fix my Chromebook screen please
完成的
I need your help today
完成的
添加一条评论
bem boom bech bum italic text eat my big bum == Heading text == heck
这个答案有帮助吗?
得分 4
2条评论:
beembold text bom
完成的
i'm the douche heheh heck xd dab
完成的
添加一条评论
It's not working what button is the refresh button
这个答案有帮助吗?
得分 2
2条评论:
the circle arrow on top row on cromebook
完成的
circle arrow right besides the arrows
完成的
添加一条评论
Just yell Reeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee and it will flip back around
这个答案有帮助吗?
得分 1
1条评论:
no don’t do that
完成的
添加一条评论
Would you fix my Chromebook today please
这个答案有帮助吗?
得分 0
添加一条评论
To fix your upside-down Chromebook screen, press Ctrl + Shift + Refresh (⟳) twice to rotate it 180 degrees back to normal. If that doesn't work, go to Settings > Device > Displays, then set the screen orientation to Standard. Your screen should return to normal!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
isaiah Barnes 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 19
过去 30 天: 86
总计 218,085
